Message |
when trying to unscrew/remove it. If I tighten it, it only goes about 30deg and gets really tight, of course then at an odd angle that oil line isn't bent to fit, and even if it could go 1 revolution, likely to hit exhaust housing on it's way around anyway. I might just be stuck with it as is till I pull motor one day to upgrade turbos. Maybe with it at the tight at odd angle, I can try to bend the oil line enough into place to connect banjo, hopefully without kinking it... Really no room to work if I wanted to try to cut it off
2+2=4; 2+0=2; 4>2 : 2+2 > 2+0. SRC="http://img19.imageshack.us/img19/7674/kzttgin a4.jpg"> Can anyone whos removed the headlights just by going through the turn signal hole, post a pic of their arms? Im just wondering if you have little tiny arms, or if you can somehow dislocate your wrists?...Im not saying im huge or anything, because im not - Ebola 23:10:42 01/20/05
